by Gaustin » Fri Jul 02, 2010 5:59 pm
Hello All.
The As-Detailed and As-Fitup terms are used in AWS D1.1 for prequalified Joint Details.
Here is how the code addresses it. This is from AWS D1.1 2004
3.12.3 Joint Dimensions
(1) Dimensions of groove welds specified in 3.12
may vary on design or detail drawings within the limits
of tolerances shown in the “As Detailed” column in Figure
3.3.
(2) Fit-up tolerances of Figure 3.3 may be applied to
the dimensions shown on the detail drawing. However,
the use of fit-up tolerances does not exempt the user
from meeting the minimum weld size requirements of
3.12.2.1.
(3) J- and U-grooves may be prepared before or after
assembly.
