GoWelding.Org
Longevity MIGWeld 140 Review!
How to Start a Mobile Welding Business
Longevity MIGWeld 140 vs. Lincoln Power MIG 140 and Millermatic 140 Auto-Set
This is a review of the Longevity MIGWeld 140 and why I choose it over the Millermatic 140 Auto-Set and the Lincoln Power MIG 140.
Since I don’t have a shop I am looking for a welder that I can work from home with and it is easy to set-up. My main three criteria for a new welder are:
  • Cost
  • Weight
  • Quality and Reliability
  • Warranty
Cost
Obviously cost is a big issue for everyone. I am not using this machine as a production welder and I don’t want to own a shop. So spending too much on a welder is not a wise decision for me. The Longevity MIGWeld 140 cost a lot less then the Millermatic 140 Auto-Set and the Lincoln Power MIG 140. Longevity makes an excellent machine for less than half of the cost and still cares about their customers. It would cost you more to take a MIG welding class then to buy this welder.
Weight
My old at home welder was a Miller Syncrowave 250 that I bought new in 1996. It does not MIG weld but since this is a home machine I needed to move it back and forth out of my storage shed to my work space. After moving a almost 400 lbs welder too many times I am sick and tired of heavy equipment. Weight has become a big issue. The MIGWeld 140 weighs less than half of what the competitors welders weigh.
My initial concern about Longevity was that they build them in China. Chinese equipment like Harbor Freight is disposable garbage that just does not last. Longevity builds their equipment in China but engineers it themselves. This is the same thing Apple computers does and many other high tech American companies do. The quality of their welders is excellent!
Warranty
Finally the warranty tells you a lot about the welder. Longevity welders have a standard 5 year warranty verses Lincoln and Millers 3 year warranty. It is a safer bet to get a welder with a better warranty simple because you are covered if it breaks. If I can beat the hell out of a few hundred dollar MIG welder for five years then I have gotten way more than my money’s worth!
Longevity MIGWeld 140, Millermatic 140 Auto-Set and the Lincoln Power MIG 140 Facts
Here are the facts about these three machines side by side directly from the manufactures:
Longevity MIGWeld 140 .
Millermatic 140 Auto-Set .
Longvety MIGWeld 140
Price
$349.99
$755.00
$734.00
Weight
40 LBS
60 LBS
71 LBS
Warranty
5 Years Parts and Labor
3 Years Labor 5 Years Parts
3 Years
Duty Cycle
20% at 90 amps
20% at 90 amps
20% at 90 amps
Wire Diameter
MIG Wire .025 and .030
MIG Wire .024 and .030
Flux Cored Wire
.030 and .035
.030 and .035
.030 and .035
Spool Gun
Yes @ $119.99
Yes @ $276
Yes @ $261
Equipment Included With These MIG Welders
All of these MIG welders come with everything you need to get started MIG welding except a bottle of gas for MIG and that includes the following:
  • A MIG Gun with all needed accessories.
  • Ground clamp.
  • Gas regulator.
  • Gas hose.
  • Sample electrodes.
  • Spindle adapters and rollers.
The only thing the Longevity comes with the others don’t is a welding shield, wire brush and chipping hammer. Thos are absolute garbage! If you buy this machine you might as well throw those out because that is the typical Chinese made crap I expected. Now I did get a Longevity auto darkening welding helmet and that is a nice helmet but that is another story.
Accessories Quality and Feel
The MIG gun, cables and all of the accessories feel solid and of the same quality you get from Miller or Lincolns competing models. The liner, MIG tips, cone and even the regulator work just the way you would expect them to. There are no issues with the feel and quality of the equipment. Again this is not the disposable Chinese Harbor Freight quality!
How Good Does The Longevity MIGWeld 140 Actually Weld?
Here is the BIG answer everybody wants to know! To start I have to say I expected a lot less and I was way wrong! The MIGWeld 140 produces excellent welds. I beat the crap out of this welder trying to pop the duty cycle fuse running at 140 amps on a welding table project. No matter how hard I pushed this welder I could not get it to pop its beaker. Your gloves will start smoking from the heat of the weld before tha overload circut kicks in!
The welds had excellent penetration and I tested both solid MIG wire and Self Shielding Flux Cored Arc Welding Wire. Most of the time when I MIG weld the machines are typically a Millermatic 252, Millermatic 350P, Miller suite case with a XMT power source or a Miller Deltaweld (High power machine for heavy plate). For such a small welder it did really well. So here are the welds.
Welding Business Plans and Ideas
Longevity MIGWeld 140 Welding with .025 ER70s Series MIG Wire Test Results
Before beginning I want to say that I have not welded for a long time so I am way out of touch. My welds are not what they normally are when I weld every day.
To start during this test I was also building a welding table for my home and I pushed this welder a lot further then it was designed to weld. Longevity’s manual says when welding with a .025 MIG wire you should not exceed a metal thickness of 12 gauge but I had no problems welding 3/16 flat bars to 1/8”plate and later 1/8” thick angle to ¼” plate with excellent penetration (I accidently erased the 1/4 plate picture). Finally I welded a 1/16" thick flatbar. Below are the welds I did.
The two pictures on the right are MIG welds done MIGWeld 140. The first picture is a fillet weld test done on 3/16" thick flat bars. The machine is not designed for MIG welding this thick material but it did great.
The second picture is a 1/8" thick angle welded to a 1/8" plate. Boths welds came out good.
Longevity MIG 140 Test Weld Longevity MIGweld 140 fillet weld 1/8" angle to plate
The first picture on the right is a close-up of the weld penetration done on a 1/16" thick flat bar. As you can see the machine hase more power then Longevity says it does.
The second picture is the back of a 1/8" plate that was welded with the MIGWeld 140 and as you can see the mill scale blistered. That is a good sign of penetraqtion.
MIGWeld 140 Weld Penetradion 1/16 Sheet Metal Longevity MIGWeld 140 weld penetration 1/8 plate
Longevity MIGWeld 140 Welding with .030 E71T-11 Series Flux Cored Wire Test Results
The Self Shielding Flux Cored Wire welded thicker metals with no problem. You can weld 1" plate if you want to and get good penetration as long as it is done with multi pass fillet welds.
The pictures below are done on 7/16 inch thick plate with the 030 E71T-11 self shielding Flux Cored Wire also know as Gasless MIG welding. The first weld was done it the flat position, the second is a verticlal up fillet root weld and the last is a weave weld. They all did great and penetrated with no problems.
Gasless MIG weld done in the flat position Self shielding Vertical Up Root weld Gasless MIG weld weave vertical up
The Final Word On The Longevity MIGWeld 140 MIG Welder.
When it comes to this welder Longevity describes its equipment perfectly.
“The LONGEVITY MIGWELD 140 delivers industrial quality and performance at an affordable price”
This little machine is priced right at half the cost of competitor models, weighs less the Millers and Lincolns models, has a superior warranty and performers better then Longevity states in their manual. Overall I would recommend this welder to anyone from the at home welder to a body shop all the way to sheet metal welding/fabrication business. The machine delivers more than it was designed to do and does it an affordable price. What more can you ask for?
Welding table build using Longevity MIGWeld 140
Go Welding.Org. © 2008 - All rights reserved.
