Celtic Engineering - Welding, Fabrication and Marine Services
Celtic Engineering is a certified welding and fabrication contractor with over 30 years of experience servicing South Florida. We are a small company that provides High End welding and fabrication services for a variety of industries. Let our highly skilled crafts people do the work right the first time and on time. If you need a company that is honest, organized, clean, punctual and has reasonable rates. Then feel free to contact us!
17648 86th Street N
Loxahatchee, FL 33470-2636
Phone: (561) 472 - 4039
How We Save Your Business Time and Money
When it comes to welding and fabrication there are many pitfalls that can spiral costs out of control! The three things that we foucus on to prevent excessive costs are:
- Planning
- Communication
- Working with Highly Skilled Personal
When it comes to planning we work one on one with your engineers, project or plant managers and even your yacht captain. Well planned out projects go smoothly and there is minimal down time for your business. Unfortunately when hiring most contractors there is little planning because they are eager to start billing you by the hour for started work. The end result almost always cost the company more money at the end of the project. That is why we will share our expertise at no cost to you before the project starts!
We always communicate clearly in English with our clients from the beginning to the end of the job! If any new issues arise you will know firsthand about any plan changes or possible delays. This many times helps avoid expensive time consuming mistakes that could have been avoided by simple communication!
Celtic Engineering is personally run and operated by the founder of the company David Reakes. Dave personally works on and oversees every job. All other personnel are at the journeyman level or higher and have a minimum of a 6G welding certification. No matter how difficult the work is we can get it done. Everything from yacht repairs to nuclear power plant welding. |
Welding and Fabrication Services
We do a variety of work and specialize in high end welding and fabrication. Below is a list of the types of jobs we typically do
- Marine Service
- Cruise Ship Repairs
- Yacht Repairs
- Plant Maintenance
- Nuclear Power Plant Welding Services
- Pipe Line and System Installation
- Heavy equipment Repairs
- Plant Alterations
- Steel Building Erection
- Fabrication
Go Welding.Org. © 2008 -
All rights reserved. |
