MIG Welding Aluminum
How to Start a  Welding Business
MIG Welding Aluminum and Everything You Need to Know on How to Get Started!
MIG welding or Gas Metal Arc Welding of aluminum is easily done and only requires a little extra equipment and skills. Extra equipment will be needed no matter what and if welding out of position it will require a journeyman skill level (that’s an understatement). Aluminum welds very well with MIG and it is best used on thicker materials that are in the flat position. You can weld thinner materials and out of position but those areas are only for the highly skilled and experienced aluminum MIG Welders. In most cases even if you are an experienced welder this is going to be very difficult to learn because of the way the puddle looks and the fast travel speeds used to weld out of position.
Spool MIG Gun Aluminum MIG Welding Technique Electrode Angle MIG Welded Aluminum
Welding Business Books
Pro’s and Con’s of Gas Metal Arc Welding Aluminum
  • Fast Weld Deposits
  • X-Ray Quality Welds
  • Welds in All Positions
  • Needs Special Equipment
  • Has Difficulties Welding Thin Aluminum
  • Requires Highly Skilled Welders for Out of Position Welds
The bottom line is, the bottom line, if you need to deposit a lot of filler wire in a production driven environment, then this is the right choice for this non ferrous material. This is all depends on the thickness of material that will be welded. You need the base material to be thick enough to handle the heat and most welds should be in structural shape form. The main trade off is the skill level needed to weld out of position. For most situations this makes MIG the choice of production welding used in shipyards, trailer building, and aluminum tank construction. The proof is in the skills level needed that shipyard staffing companies expect. For most recruiters hiring pipe welders (career welders who travel for work) they expect about half of the welders to fail their 6G restricted x-ray weld test. That is just a given! On hiring aluminum MIG welders they expect 9 out of 10 welders to fail the test. If you need to know, the test is a 2G, 3G and 4G ½ “ plate test that gets x-rayed. Not a big deal but that just shows the difficulty of MIG welding aluminum out of position.
Aluminum MIG Welding vs. Aluminum TIG Welding
If you have a choice of processes for welding aluminum then it all depends on thickness of the material. MIG welding is great on anything that is 1/8 of an inch or thicker and is in position. TIG welding works best on thinner stuff and pipe.
Aluminum Gas Metal Arc Welding (MIG) Electrodes and Gas Selection
When it comes to welding Aluminum the Gas and electrode choices are pretty simple! In almost all cases the gas choices are:
  • Argon (99% of the time)
  • Argon/Helium
That is about it! The Argon/Helium mixture is only used on aluminum that is thicker then 1/2 of an inch. The helium mixed into the Argon helps create a hotter arc to penetrate aluminum. If needed you could still go with 100% Argon gas for heavy plate aluminum MIG welding!
Electrode selection is depends on the base metal and thickness. This is another area you should talk to your local weld supplier about. They know what products work best for what materials. In most cases your aluminum electrode wire selections and designations are:
  • ER4043
  • ER5356
Pretty simple! Here is the deal, you typically don’t want to use a wire thicker than .035 and the high the number the stiffer the wire. The ER5356 wire is much stiffer then the ER4043 wire. What that does is effect how the wire will act in the wire feed system. Remember the special equipment is needed because the wire is too soft to feed the regular way. So any wire that is stiffer will have less trouble passing through the liner and to the gun.
Equipment Needed for MIG Welding Aluminum
If you want to weld aluminum you are going to need some additional equipment to add to your MIG welders wire feeder. The reason is the aluminum filler wire is so soft it gets jammed and tangles in a regular wire feed system. You choices come down to adding either a:
  • Push Pull Wire Feed
  • Spool Gun
The push-pull wire feed system is most commonly used on factory floors. The way it works is the wire feeder pushes the wire as it normally would. Then the pull system is another feeder in the handle of the MIG gun that pulls it. This system works great when everything is set-up properly. The trick is to set-up the push-pull system properly (the hard part) then everything else is fine. The pro of this system is large wire spools can be used and down time is minimal.
The first picture below is a double rollers push feed on a Millermatic 350P MIG Machine. The second and third pictures below are the bottom view, and top view of a Python pull feed gun.
Millermatic 350P Double roller push feed Python Pull feed Gun Bottom View Python Pull Feed Top View of Rollers
The spool gun is the best choice for welding out of position and small jobs. It is the most trouble free of the wire feed systems but comes with a price. The wire can only be 1 lb (typically a 4” max diameter spool) or less in size. Not a good thing when it comes to production welding but again it works well in all positions.
Spool MIG Gun Inside of a Spool MIG Gun
Finally you will need to replace the rollers on the push system on the MIG welder or wire feed system. Roller sizes vary depending on the size of electrode that will be used. This is one of those questions you will to ask your local weld supply shop about. They know the equipment and supplies. Hey they even know what brands to stay away from and witch one are worth shelling out the extra cash for.
How to Preparation the Joint for MIG Welding Aluminum
When it comes to MIG welding aluminum joint preparation is a must. The obvious apply, but the cleaning methods change. Rule #1; you don’t want to grind the aluminum with a grinding disk made for steel or stainless! With aluminum you have three ways of cleaning the joint:
3/8" Aluminum Weld Joint
  • File the Joint
  • Sanding
  • Wash or Dip It in an Acid Bath
For rough stuff sanding or filing is fine! But if you are building a product like a ladder then an acid bath is you best choice. If it is rough work you can add a flapper sanding disk to your grinder or just grab a piece of sand paper and go to work. The acid wash works great but there are some serious health issues when using acid. It all comes down to the needs of the product, how it must look finished and what your budget is.
Distortion from Welding Aluminum
Welding aluminum is one of the few metals that do not require much bracing of the joints. There is minimal distortion and not too much to worry about. You just don’t get a better metal to work with.
Machine Set-Up – Transfer Type – Over Heating Issues
If you are ready to MIG weld aluminum then you need to know how to set your machine right! On many welding machines there is a chart that gives a recommended wire feed speed setting and voltage range. These are your BASIC Guidelines but you need to be adjusted till you get the right setting.
Welding business ideas, suggestions and ideas.
Arc Transfer Types
There are two three transfer types when MIG welding aluminum and they are:
  • Globular
  • Spray
  • Spray Pulse
In most cases the weld will be done in a spray transfer mode. If you are lucky enough and have one of those pulse spray machines then the job will be much easier. Globular is used on thinner metals because the voltage setting is not high enough to produce a true spray transfer.
MIG welding aluminum is position is done with a true spray transfer but welding out of position is either a globular or a spray transfer. The difference between a true spray transfer in the flat position and out of position is the sound of the weld. In position produces a hum or hissing sound. Out of position aluminum welding produces a FAST Crackle sound with white sparks flying and occasional spatter.
Pulse spray takes advantage of varying the voltage so that the spray arc never gets to hot and never gets to cold. The best way to describe it is almost like spot welding but never shutting down the arc. It is a series of hot and cold welds that are working compensate for a lack of skill. For out of position MIG welding pulse spray cannot be beat.
Aluminum MIG Welding Settings
The settings needed to MIG weld aluminum are pretty much the same for all positions. In most cases it will take 21 to 23 volts to get the arc to spray transfer. If welding out of position you will want the wire feed speed fast enough to keep the weld full of metal at a fast crackle. Aluminum requires the wire feed speed to push the wire into the joint. If it slows for any reason you get a fused tip or get a weld that does not stick! Don’t be scared to turn up the wire feed speed!
Over Heating of Aluminum
The BIG ISSUE when setting up you machine is the TEMPERATURE of the aluminum! If you are welding cold aluminum or spot/tack welding then machine setting are not issues. On the other hand is you are welding joints then temperature is a BIG ISSUE. When you start to weld a joint that is cold it will seem the heat is to low but as you go on the heat settings will seem too high. That is the BIG ISSUE with aluminum! The BIG DOWN SIDE OF OVERHEATING is the entire JOINT WILL TURN TO MUSH and FALL to the FLOOR WITHOUT WARNING. Yeah it is all going fine and all of a sudden it all just literally falls apart! This issue affects all types of aluminum welding that use an arc or flame to melt the metal.
One of the reasons it is so difficult to detect the joint is overheating is the fact that the molten puddle does not look much different than the base metal. The puddle looks like tin foil moving. If this were steel there would be a bright red glow, the joint spitting sparks and you would clearly feel the heat is way too hot. Aluminum just requires a feel and experience to know that the temperature is not t0o hot. If you really want to be safe you can always get a heat stick to keep marking next to the weld to test the temperature.
MIG Welding Techniques For Aluminum and Magnesium
The techniques are no different except for the speed you need to keep in order to weld out of position. If welding in position there is lots of room for error because you have time to react. On the other hand out of position welding is more of a gut feel! Techniques for MIG welding aluminum are forehand welding and in most cases stringer beads only (yes you can weave but it is not worth risking overheating a joint). Out of position welding is a fast whipping or steady motion with a focus of staying ahead of the puddle. It is very odd traveling so fast compared to other welding processes and that is why the fail rate is so high among the shipyard welding tests.
MIG Gun Forehand Welding Angle Aluminum MIG Welding Technique Electrode Angle
When MIG welding aluminum the technique used is always forehand and you need to push the puddle. These two pictures show the proper angle when MIG welding aluminum.
3/8" Aluminum Weld Joint MIG Welded Aluminum
Welding thicker aluminum out of position works well but the weld appearance is never perfect! The aluminum weld in the picture is a single pass and took about 10 seconds to do on a 3/8" bevel. It’s all about moving quickly and keeping the puddle from rolling over.
Go Welding.Org. © 2008 - All rights reserved.
